anyone using a visualiser with qlc+
Aidan Vogt
Real Name: Aidan Vogt
I would be interested in using one
TheBelette
I have used Capture (http://www.capturesweden.com) on MAC, a free student version is available with several projectors.
It use Artnet to communicate with QLC.
You can also use Magic easy view 3D for PC only or MAC with parallel, it's the same think you send the DMX to the visualizer via Artnet.
Aidan Vogt
hey there, thanks.
I have capture but have never been able to get it to work with qlc.
big ask but can you give some pointers to get it happening.
also found that the free capture doesn't have any fixtures, i am sure i am doing something wrong.
TheBelette
First launch Capture then QLC
On QLC check the output artnet you will see the Capture Node.
Configuration on QLC
And then you go to Capture on the DMX univers you select the ArtNet for the Universe 1.
Configuration on Capture
You also need to patch your projectors on Capture with the same address as in QLC.
Aidan Vogt
great thanks.
I found the library add on to.
will let you know how i go
Aidan Vogt
Thanks that was really helpful.
I downloaded Argo student but it opens as demo, and I can't save my project
Ever seen this?
Emekaao
Real Name: Emeka Achebe-Okosieme
TheBelette wrote: Wed Apr 29, 2015 8:50 am First launch Capture then QLC
Thanks for the heads up. It was really helpful.
How do I patch projectors on Capture with the same address as in QLC?
Emekaao wrote: Thu Apr 07, 2022 2:03 am Thanks for the heads up. It was really helpful.
I think this is a question for Capture users rather than QLC+ users
BTW there's plenty of tutorials about it:
https://www.youtube.com/watch?v=WRb7sRn ... lisationAB
Emekaao
Thanks for your response.
I am able to find my way around now.
