Hey all! I just picked up a pair of Inno Scan LED's by American DJ (the discontinued ones) and I would like some help making a fixture definition for it. I have attached the PDF with the dmx addressing for the fixture to this post. Thanks in advance!
Also, Massimo if you see this I had sent you a private message on sourceforge so if you could kindly disregard that haha
Inno Scan LED
- Real Name: Andre
- inno_scan_led.pdf
- (1.02 MiB) Downloaded 81 times
- pipolino419
- Real Name: Rodolfo
Try this file and let me know
- American-DJ-Inno-Scan-LED.qxf
- (7.31 KiB) Downloaded 75 times
- Real Name: Andre
Thanks for the assistance. I'm running version 4.8.4 of QLC+ if that has anything to do with me not being able to import the fixture properly. The import option asks for .qxfl files and the one you put was a .qxf - and when switched to all files and I select it then nothing happens.
I've added this to QLC+. I've fixed PAN/TILT range - I suppose it's 180/70, instead of 540/270. In the manual there are both numbers, which I consider a bug.
