Set Master (GM) from controller
Joep Admiraal
I have searched the forum and the help function in program.
Is it possible to adjust the GM from a Midi controller?
It would be nice if I can use my master fader from my Midi controller as a master for my light show.
Thanks,
Joep
Massimo Callegari
Seems you haven't searched enough ;)
On Virtual Console, click the Settings button (screwdriver icon) then go to Grand Master tab. There you can assign an external controller
Joep Admiraal
Ah, got it. Thanks!
wmlamplighter
Real Name: Myles Stawman
Yes, thank you. And while I'm about it, thank you from the bottom of my heart for all your work on this program. Brilliant.
