Problems pan and tilt head hurt me, do not work well in reverse set Qlc, other software are set to reverse the very beginning, you can add the set reverse in part Fixtures - add an option to reverse X / Y for each individual. EFX does not really stand out, while the reverse applies only to the PAN, no direct intervention by clicking on the graph makes the action very long. steps I have used to create reverse mode is required. You can edit and add some features that are very thank you, your software is great.
Add one more error in the post to me, I am using windows 7 operating system
Help me , Reverse Pan / Titl and EFX .
I did quick attempt at reverse PAN/TILT, but I didn't get too far, since the reversal must be done on very low level. We have to do the reversal very late in the chain, so that all possible sources of DMX data get reversed (EFX, Scenes, Simple Console, Channel Groups,...). On the other hand, the object at the end of the chain doesn't know which channels are to be reversed.
Version 4.3.2 fixes and features EFX has reverse but it does not have the option to reverse the PAN, TILT reverse which should contribute to the overall good of not tweaking, the version 4.3.2 has been significantly upgraded, feel Thank you very very much.
For example, as shown:
- reverse%20pan%20tilt.jpg (3.97 KiB) Viewed 933 times
- FIX%20XY.jpg (2.56 KiB) Viewed 933 times
