Function wizard bug v4.6.0
Goran Kovacevic
Hello!
I just noticed that function wizard ignores second color wheels and second or even the only gobo wheel on moving heads.. Noticed with Geni OBY 5 and Prolights XP575.. Haven't tested it with other moving heads..
Best regards,
Goran K.
Goran Kovacevic
anybody else encountered the same bug?
Jano Svitok
I can confirm the bug. Massimo, the problem si probably somewhere around here: https://github.com/mcallegari/qlcplus/b ... r.cpp#L488
Massimo Callegari
This is not a bug. It just does not handle the same capability on different channels. It works for the majority of fixtures.
The more complex ones need to wait for this functionality to be improved.
So, be patient.
pixeldoc81
Real Name: Der Phil
Would be really great if somebody could improve the Wizard to handle multiple simular Channels. It's a shame we can't use it for Moving Heads with 2 or more Gobo Wheels for Example.
Could be a time saver ;)
