Add a stop All function task to script
i would like the ability to to beable to call a Stop All functions to a script. i know the way it would have to work is the script calling stop all functions would have to be excluded if a script calls it.
- Real Name: Drew E
I'd add a second to this.
I can easily add the "stop the functions that the script started".
But if you meant "stop all the running QLC+ functions", well, then it's a mess.
I think you better use a VC button for that
- Real Name: Peter Goderie
I still have the same kind of problem in v4.12.2
For some scripts i would like to stop all running function before running the script.
Now it always takes 2 button presses, one to stop all functions and another one to start the script.
(And that first press is often forgotten when not realizing there're still a funtions running.)
It would be nice if you could set a button to "Stop All Functions" and still have the option to Start/Flash a function with the same press too.
(BTW, Button options to Start or Stop a function/blackout besides Toggle would be nice too!)
Software is the stuff that makes Hardware flexible !
