Is there a way in QLC+ to have a frame of funtions, (ie COLOR, DIMMER etc) and also have a bank of fixtures (ie UP/DOWN/LEFT/RIGHT Stage LEDs, LED BARS/PANELS), allowing me to have ONE color Matrix, and just choose the "bank" or set of fixtures that I want and change the color of them? From one place?
Also, I am curious as to how I can have a set of Functions that change color, and also have a Speed Dial that would allow me to adjust the fade in/out time. I would like to be able to have instantaneous color change sometimes, and other times, I would like to have the ability to adjust the speed of the color change, on the fly.
Thanks to everyone on this forum. I have made great leaps of ability with programming QLC since being part of the Forum.
Fixture Group Buttons
I'll say no, but I'm not sure I understand what you want to do.
You can create a speed dial that controls only the fade in/fade out times of a set of functions.
http://www.qlcplus.org/docs/vcspeeddial.html
In the speed dial properties, set the duration column to (Not Sent) in each case.
In the fade in column (or fade out column, or both), set a multiplier value.
I would like to have a set of buttons to give focus to a set of fixtures that would give color, gobo, macro control. Like this image. One set of functions that control the channels of the fixtures, but different focus assignments.
- Untitled.png (49.61 KiB) Viewed 3134 times
The goal is to have one set of color choices and different focus functions for the LEDs or Movers to allow color changes without having to make color matrices for each group. I have seen this ability on large format consoles and other software. Just curious if that is a possibility. I use all the same LED fixtures. It would just be nice to have say 20 different color choices, and then choose FRONT LEDS and hit blue, then hit SL LEDs and choose a color... and so on.
Like this, more specifically... not so much needed for my movers
- Untitled.png (23.77 KiB) Viewed 3134 times
