hello.
I'am using QLC with fire projectors, but I need to program a fire sequence while my music play. To explain better, we use backtracks during our show, and I need to program when fires erupts, according with music. I have created a button and using a shortcut i can press a button on my keyboard and have the projector to spray flames. It would be perfect if I could write down a sequence while my music plays, but I cannot found any sort of "record" feature.
Is it possible to do it?
thx
real time sequence programming
Hello Luigi
what you want to do can be achieved with the Show Manager.
Add one track with your music, then add a track with a sequence where you'll activate/deactivate your flames. That should do it.
Please read the Show Manager documentation and have a look at this page:
http://www.qlcplus.org/usage_sync.html
thx Massimo, but can I edit in real time using Show Manager? In other words, do I have to set a list of sequences "offline" or can the software do it for me wringing down my real time actions?
The Show Manager is for pre-programmed shows.
If your music doesn't change in time, that's the best solution to create a perfect in-sync show.
Live lighting is another story. You need to use the Virtual console widgets and manually follow what happens on stage.
At the moment there is no recording functionality unless you play around with the DMX dump feature and Cue lists.
Can you give us some more details of why you need such functionality ?
because I need to program a show of pyro and flames, according to my mp3 base. I have 6 fire projectors dmx controlled and I need to program some sort of show according to some particular points of each song (i.e. in some guitar riff I need 6 synchronized flames, in others I need some "bouncing" effects).
The problem is that editing the show using show manager takes a lot of time, and to sync the flames with the song is very hard.
I have create a button for each projector, and using keyboards shortcut I can manage them in real time, but if I could even edit in real time my show would be perfect, because I could edit each song in a blink of an eye.
Hello, I'm interested in this question as well. I hope it is ok to comment on the subject matter under this thread rather than start a new thread with a similar question/comment.
I'm not a professional in the lighting industry, but rather a hobbyist. I just started in electronics and DIY light controllers (DMX 16 channel dimmers). I've been having lots of fun learning about Christmas lighting controlled by computers and these wonderful DIY light control boards. However, I'm left feeling a bit disappointed by the lack of 'live' recording options to create these wonderful light sequences via many of our current software options.
QLC+ is the first opportunity I've encountered to accomplish my personal goal of recording lighting event sequences live, while listening to the audio tracks. My existing exploration to meet my goal has been the use of Ableton Live, Loopbe1 virtual midi patch, and of course, QLC+. It's an additional software package to learn and an additional opportunity for user induced error/failure.
I'm sure there are many who would love the ability to input their show via a live input method (ie: midi keyboard controller/sliders/knobs and buttons). Having a 'live record' tool in show manager to lay down multiple tracks would be great in my humble opinion.
QLC+ w/ a Vixen LIghts type preview screen & live event recording from my midi controller? That would be one heck of a nice Christmas present! : )
In all cases, I'll take this opportunity to say thank you to Massimo for this already great software tool. Love the program and my comments are just suggestions by a newbie.
I started coding a quick proof of concept for recording chasers in real time for a show. The code is forked on my github.
https://github.com/lelazary/qlcplus
To use it, set up a show and add a chaser and set the per-step for the duration. There is now a rec button next to the play and stop. Press the rec button and then play the show. Based on the fixtures in the scene, it will map the inputs where 0 is the first bar in the scene, 1 is the second etc. For now I am using a midi input, so I mapped 0 to value 128 which is the lowest c on the keyboard. When you hit the rec again it will stop. To see the values click away from the chaser and then back again.
I coded this in a couple of hours as a proof of concept. This might be highly buggy, but I wanted to see if there are any other solutions for this before going forward. The method using a separate midi software going to virtual console does not work for me (I want this to work on the pi, and there are not allot of resources).
I love QLC+, and in my option this is the one thing thats missing from it.
If you mean adding an audio track to the show and then recording the chaser while the audio is playing, then yes. This is exactly the reason for this. This way you can sync lights by playing a keyboard in real time while listening to the audio.
Hello Lior, Thanks for sharing that add-on. I've been so tied up in setting up my Halloween holiday show, I've had little time to get back onto the discussion. I can't wait to try out your add-on.
A wonderful way to give many the flexibility they may be looking for is to use a midi/daw to control QLC+. My entire show is triggered via MultitrackStudio by Bremmer. I've run the show for about a week with no glitches. (beyond those I've created myself )
This isn't on topic per say, but by using a midi sequencer as your 'show' trigger event system, you have all the flexibility one might need. Lior, your add-on sounds like it could be just the ticket. I must find time to give this a try.
Thanks for sharing.
Thanks for sharing.
- rawbengal
- Real Name: Rob Engle
Just bumping this thread... I have an application in which a friend wants to do live recording of DMX, either from a MIDI controller or in the Virtual Controller and save it to a show. Then he would go in and edit the show in the Show Editor. Any thoughts on how he might do this?
Thanks,
Rob
Thanks,
Rob
I'm afraid at the moment there is no such option to do live recording of a show.rawbengal wrote:Just bumping this thread... I have an application in which a friend wants to do live recording of DMX, either from a MIDI controller or in the Virtual Controller and save it to a show. Then he would go in and edit the show in the Show Editor. Any thoughts on how he might do this?
I am considering this functionality for QLC+ 5, but according to my priority list, it will land quite late in the process.
- Real Name: Daniel
Thanks for bumping this thread since I would probably not have found it and I always thought I'm the only guy on this planet who wants a lighting software that can exactly do this, I was very astonished that it seems there's even no commercial product that can do it.
I would also generally appreciate a lighting software that minmics the workflow of some audio production or DJ software like Ableton Live or some similar live midi sequencer. I also already experimented by using the MIDI output of Live 9 Intro for this purpose and I also achieved some nice results using the open source project giada but I ended up with my own little pure data patch since the other solutions did not work exactly how I did expected it, but nevertheless this is always some fiddle around solution and therefore very sensitive for configurations errors and very unconfortable to use.
I also considred to start a new lighting software that is specialised to do this since but since I could not even find time to dive into QLC+'s source code yet I think this would not happen in the near future - and when there's a chance QLC+ could go into this directeion I think it also does not require a new software.
By the way, I was able to achieve quite good results just by using a custom Matrix script that can playback custom sequences, unfortunately due to some behaviour within the virtual console recording a live sequence does not seem to be possible using external input (it only works in the function tab).
Since I do not want to open a new thread and this might be related more or less, how about "dynamic scenes" that have some similar functionality like rgb matrix effects but where not only color information can be stored (and maipulated using midi input). I currently use a plain color rgb matrix effect for every rgb device since it's color can be changed dynamically, my chases just call these "rgb matrix scenes". I would love to have such a possibility simply for every possbile channel of a single or a group of fixtures and I think such a dynamic scene with just some more features could maybe already serve as a live sequencer since the rgb matrix can almost already do it.
Greetings,
Daniel
Greetings,
Daniel
- Real Name: Kevin
Hi, I know this is an old thread but is this fork still available? I need something that will allow me to sync up the singing parts of a song to a few devices. It's inconsistent. I'm getting all errors on building this in QT. Thank you
