Audio Track preview waveform NOT matching timeline view
SDerMan
I just noticed that on the audio track, if I import an mp3 file the previewed waveform doesn't match the sound. The music playing back is not in sync with the visual waveform.
I tried importing a .wav file, and that seemed better.
Also any chance of handles for increasing and decreasing regions on the tracks. Asking for for fade in/out handles may be too much, but asking anyway. :-p
Massimo Callegari
Hi, which OS ? Which Show manager scale are you using ? Which MP3 format ?
Handles have been asked a few times already and the answer is always the same: QLC+ is not an audio sequencer. Sorry.
The best I can do for now (which is in my TODO list) is audio fade in/out
SDerMan
Using Mac OS X 10.8.4. I don't follow what you mean by Show Manager Scale. Its 192kbps 44.1KHz mpga stream.
Not asking it to be a audio sequencer, Thanks for the quick reply.
Massimo Callegari
The Show manager scale is that gray slider above tracks and on the left of the timeline. If you set to 1:1 (all left) things should get better.
As for sync issues, I'm afraid this is Mac related, even though I tried a simple metronome track and it seems to be ok.
See my previous posts about this.
https://sourceforge.net/p/qlcplus/discu ... it=25#1d65
https://sourceforge.net/p/qlcplus/discu ... /1be8e988/
https://sourceforge.net/p/qlcplus/discu ... it=25#ca2c
SDerMan
The scale is set to 1:1 and it still happens. doesn't seem to happen with a wave file though.
