Not tested in real condition, would work, but is my first fixture.
based on hjunnila original SGM Giotto spot 250 fixture
SGM Giotto Spot 400 CMY
ecco il file .qxf
- SGM-Giotto-Spot-400-CMY.qxf
- (12.3 KiB) Downloaded 93 times
[EDIT] Where did you get the DMX chart for this fixture ?
I cannot find it on the SGM website.
I found Giotto 400 Spot and it has 22 channels, and not 33 as in your fixture
here the link for the pdf http://www.madmanproduction.com/manuali ... manual.pdf
I know that SGM have removed it and I think to know why... this moving-head isn't a bestseller... had a lot of small problems and there are a lot of similar products better of it...
it isn't a profile but the beam angle is very closed (11 to 22 degrees), the gobo indexed movement isn't fine and running different positions, when you return at the original position, the indexed position of the gobo is lost... the colour mixing is defective and the macros about the 2 gobo wheels are hard to use...
but unfortunately I'm sometime work in a theatre that had buyed 6 of thems...
up to 1 year ago, the Giotto 400 CMY was in the product list of SGM site and I've downloaded and printed the manual but in the recent changes of the SGM website it was removed... I think that no one will cry for it...
