Building on Debian - missing [HINT]
Paul Evans
When building a debian package, you may find that compilation stops due to being missing.
I found that this is available at
http://www.opendmx.net/index.php/OLA_Debian_/_Ubuntu
Add the repository using the given instructions, then
sudo apt-get install ola-dev
then the QLC+ package should build successfully.
Massimo Callegari
Moved to the development thread.
Have you followed the Wiki ? https://github.com/mcallegari/qlcplus/w ... uild-HOWTO
Paul Evans
Ahyes; I hadn't found that page. Thanks.
Massimo Callegari
It's linked from the QLC+ website: http://www.qlcplus.org/
