QLC+ TEST versions
Great, thanks.
Then there is something corrupted in the Appveyor environment :(
Another unwanted thing to spend time on...
[EDIT 2021-08-27] the issue seems to be fixed upstream now (4.12.5.29 works)
lorenzoandreani
Real Name: Lorenzo Andreani
Tsurugi wrote: Fri Jul 16, 2021 1:49 am hi, I wanted to try version 4.12.5.8 but it doesn't start with this error, the previous version starts regularly
On Windows 10 - 10.0.19044, i have the same error using this versions:
QLC+_4.12.5.62.exe
QLC+_4.12.5.79.exe
QLC+_4.12.5.83.exe
the latest version that start is:
QLC+_4.12.5.29.exe
markzvo
Real Name: Mark Z
lorenzoandreani wrote: Thu Dec 02, 2021 1:30 am
QLC+_4.12.5.62.exe
QLC+_4.12.5.79.exe
QLC+_4.12.5.83.exe
QLC+_4.12.5.29.exe
I am also seeing this behavior
I confirm this issue and unfortunately I haven't found a solution yet.
As a workaroud, you can copy all the DLL files starting with 'lib' (lib*.dll) from the official 4.12.4 package and the TEST versions will work.
lorenzoandreani
mcallegari wrote: Fri Dec 03, 2021 6:06 pm As a workaroud, you can copy all the DLL files starting with 'lib' (lib*.dll) from the official 4.12.4 package and the TEST versions will work.
Ok, it works
Latest Windows test version should be OK now
markzvo
Real Name: Mark Z
I can confirm that latest test version installs OK on Windows now
edogawa
Real Name: Edgar Aichinger
I wanted to let you know that I've just enabled Ubuntu 22.04 builds in our Open Build Service area.
No problems occurred, the builds just succeeded, but haven't been propagated to the download page yet, I expect that to happen within the next few hours.
AliFa
Real Name: Ali Fara
I have problems with sequence management, except that in the online converter it converts normally, as it should be?
WorkTime - no invasion to employee’s privacy.
BlandSauce
It appears that the most recent Windows Test version (QLC+_4.12.8-20231110) does not load custom stylesheets. The other older version I have (QLC+_4.12.8.36) the sylesheet is loaded correctly.
BlandSauce wrote: Fri Dec 15, 2023 8:11 am It appears that the most recent Windows Test version (QLC+_4.12.8-20231110) does not load custom stylesheets. The other older version I have (QLC+_4.12.8.36) the sylesheet is loaded correctly.
viewtopic.php?t=16688
