QLC+ TEST versions
lorenzoandreani
Real Name: Lorenzo Andreani
Re: QLC+ TEST versions
Post by lorenzoandreani » Sun Apr 23, 2017 3:28 am
QLC+_4.11.0.1 (22/04/2017) on Windows 10 crash when open a .qxw workspace.
I think the problem is due to the new sequence management because if you convert the file to the online converter, the problem does not occur.
Crash Sequence.qxw
(124.07 KiB) Downloaded 49 times
Post by mcallegari » Sun Apr 23, 2017 7:46 am
Indeed, after a recent rework on Sequences, backward compatibility is interrupted.
However, QLC+ should not crash and should show an error message saying that projects using sequences must be converted to the new format with the migration tools.
Anyway, I've fixed the crash on GIT, thanks for reporting.
nedmech
Real Name: Nathan Durnan
Post by nedmech » Mon Jul 10, 2017 12:27 am
Finally got around to trying out 4.11.0 on my oldest production machine only to encounter the following error:
"Procedure entry point CancelIoEx could not be located in the dynamic link library KERNEL32.dll"
This particular computer is still running Windows XP (for various reasons). I'm assuming that compatibility with Windows XP has now been broken by the change to QT 5.9? The QT support page only lists Windows support back to Win7 (http://doc.qt.io/qt-5/supported-platforms.html). Can you confirm if that's really the case, or is this some other glitch I've run into?
janosvitok
Real Name: Jano Svitok
Post by janosvitok » Mon Jul 10, 2017 7:25 am
Post by mcallegari » Mon Jul 10, 2017 12:05 pm
At this point, I think bundling Qt 5.9 was a mistake.
There's been reports of issues also with older macOS versions.
Most likely 4.11.1 will bundle Qt 5.6.2 again but guys, I cannot support dinosaurs forever.
The world is moving on:
- Microsoft even stopped XP support
- Apple is constantly polling you to update to the very latest macOS version...until your Mac (or iPhone/iPad) will need to be thrown in the trash can
I don't understand why QLC+ can't adapt to these tendencies.
I really hope QLC+ 5 will draw a line on this. In any case Qt 5.9 will be the minimum version required for technical reasons.
nedmech
Post by nedmech » Tue Jul 11, 2017 3:14 am
Thanks for confirming this, Massimo & Jano. I've got no problem with QLC+ moving forward and dropping support for XP. I plan to upgrade that machine to Windows 10 soon. I'm mostly waiting on my IT guy to actually purchase what we need to upgrade it.
Post by mcallegari » Mon Jul 17, 2017 6:38 pm
I have reverted to Qt 5.6.2. Now test builds should work again on XP and Vista too.
I'm wondering though if in keeping Qt back we're missing something valuable, like for example multimedia improvements.
Apparently not (the damn issue of 0x0 videos has not been fixed (in years) yet) but still, the doubt remains.
soundupinc
Real Name: Nikolay
Post by soundupinc » Thu Aug 31, 2017 5:04 am
Hello
thx for great software)
yesterday we hava test QLC+_4.11.1.90.exe
we use QLC with Akai APC Mini in 4.11 we have seen that Slider VALUE RANGE, don`t see limits (low limit and hight limit) when we use Slider on AKAI. all ok with this is in 4.10.5
dino.loss
Real Name: Dino Loss
Post by dino.loss » Fri Sep 01, 2017 8:57 am
hi,
You're right, same problem!
I did the test with QLC+ 4.11.1.154 with APC Mini and Windows 7
On the attached workspace the limit value is set between 8 and 134 and the monitor can vary from 0 to 255
slider-limit.qxw
(2.4 KiB) Downloaded 19 times
AKAI APC mini
Behringer Eurolight LC2412
Enttec DMX USB PRO MK2
Windows 7 64
Post by mcallegari » Sat Sep 02, 2017 10:02 am
Should be fixed now, please test version 4.11.1.162.
Thanks for reporting
