Partial Blackout function
Geoff Jung
I have a virtual console set up and it's working well. Is there a way to add a partial blackout button to black out all but a few defined fixtures? I've tried to add a scene with all the wanted fixtures to black out, but it seems that the it will not override the current light scene.
Thanks.
RickBrock
HI Geoff, I'm no expert but...
A scene should simply be a set scene, and you should be able to call set a scene which will overide your previous scenes no?
Have you zero'd everything in the simple desk before trying this? start from scratch... otherwise the HTP (highest takes priority) rule from setting on the simple desk will override the scene you called.
hope that helps
Rick
