[20140326] OSX TEST version - Qt4 based
Massimo Callegari
This OSX snapshot is mostly here to test the HID plugin with the FX5 adapter.
It obviously includes also all the changes made after 4.7.0 RC1.
Download here: http://www.qlcplus.org/4.7.0/QLC+_4.7.0 ... 140326.dmg
Joe
Thanks Massimo. Really appreciate these snapshot builds.
Stefan Flocker
Hi Massimo,
just tested it with FX5 interface - is working!
**Well done, Massimo!**
But there is another issue, which I found in Windows and Mac versions:
* Create a new scene, e.g. with one generic RGB fixture.
* Do settings in this scene (e.g. set up Dimmer & RGB values).
* => Fixture shows the result.
* Copy (duplicate) this scene.
* => All scenes fail to work (click on scene - fixture stays dark, the 'monitor' display shows '000' values for all outputs). You need to store the workspace, quit and restart QLC+. Then the scenes react again. Seems as if the 'copy' does something wrong.
Regards
Stefan
Sascha Büttner
To push this issue again, I too have problems with the COPY function while creating scenes.
I'm on OS X 10.9.3 and QLC+ 4.7.2.
While creating scenes for my 8 Head LED Bar to set some chasers I heavily use the copy feature. Doing this leads to random crashes of the app. I started saving the workspace before every copy process to ensure not loosing steps.
Any known workaround or a known bug in revision?
(Massimo: I don't want to complain all the time. In fact, I really love your software and appreciate your amazing work. I just think, you can not fix such problems if none reports them. And reporting is, what I can do to help. ;-) )
