Hello everyone,
I have a question about the show editor.
I have an audio file with a length of 1 minute.
While the audio file is being played, the values on different generic dimmers are slowly increased to 100%.
When the song/show stops, all generic dimmers should keep the last values (100%) at the end. The values should NOT be set back to 0%. The spotlights should remain on indefinitely.
Only when the next show is started should the values be changed again.
Can someone tell me how I can realize this?
Best regards
Jelu
Show editor - no turn off at the end of the show
- Real Name: Jens Fleischer
Windows 10 Home
version 22H2
build 19045.4412
version 22H2
build 19045.4412
Easiest way to achive this is changing your fixture to LTP mode. https://docs.qlcplus.org/v4/fixture-man ... properties
As long as you don't instruct your fixture to go dark, they will hold their last value. (Latest Takes Precedence)
Thank you!
Windows 10 Home
version 22H2
build 19045.4412
version 22H2
build 19045.4412
