Hello People of all kinds,
I am currently preparing for a theatre show where I will use a bunch of Dimmer channels to control LED strips of approx 2m length, with a particular layout. Programming time at the venue will be restricted, so I will have to "blind" program quite some sequences and scenes. for this I wanted to use the 3D view of the Output Monitor. Unfortunately, I noticed that each channel is represented as a circle where a dimmer is a rectangle. so a dimmer with one channel van be represented as a long rectangle with only a smill circle that will light up.
Now my question: is it possible to modify the shape of the circle so that it fills the entire rectangle? any lightbatten or other than round shaped fixture could benefit from this I suppose.
Thanks for any suggestions.
fixture monitor 3d view
How did you setup your fixture? It looks like it is a 1m long batton with only one head - this is the normal way of representing things.
