Ubuntu: no audio devices?
tripleb
Real Name: Alexander
I just installed QLC+ a clean Ubuntu 22.04 on a Lenovo Thinkcenter M910q
Nice small PC - nearly everything fine so far:
  • network connections, automatic login
  • automatic QLC start /w web server enabled, running local in fullscreen mode and running a default qxw
  • OSC connection
  • MS Remote Desktop access from my MacBook
Currently I'm waiting for my Dummy DisplayPort Device to get rid of the Monitor, mouse and keyboard :)
What I did not get working so far: the audio input - QLC+ only shows the standard-device - however I get no inout signal
On the Ubuntu Desktop I can hear audio playback going through the inbuilt speaker or the headphone socket. The output is shown in system settings. However the input setting is a blank field with no devices.
If I open Audacity I can select the Mic device (ALSA) for input and cleary see level on the input meter
Where do I start to check my current installation, what does QLC+ need (additionally?) to list the inbuilt mic input of this M910q?
Edit:
qlcplus@lighting:~$ arecord -l
**** Liste der Hardware-Geräte (CAPTURE) ****
Karte 0: PCH [HDA Intel PCH], Gerät 0: ALC294 Analog [ALC294 Analog]
  Sub-Geräte: 1/1
  Sub-Gerät #0: subdevice #0
Karte 0: PCH [HDA Intel PCH], Gerät 2: ALC294 Alt Analog [ALC294 Alt Analog]
  Sub-Geräte: 1/1
tripleb
I answer myself:
with the information from http://www.qlcplus.org/forum/viewtopic.php?t=15778 I was able to get a list of the audio devices in QLC+
I.e.
sudo apt-get update
sudo apt-get install libqt5multimedia5-plugins
I think this dependency should be added to the install pkg ;)
