GPIO input plugin
marcopiro
Real Name: Marco Piro Pirondini
Dear QLC+ friends,
strange behaviour today on a fresh RPI install.
When I try to configure the GPIO Plugin on the debug console I get:
[GPIO] error in opening direction file "/sys/class/gpio/gpio18/direction"
and the input/output behaviour is not possible to set. :shock:
GPIO pins are initialized as input, pullup in /boot/firmware/config.txt
Any ideas???
Many thanks,
with love,
Marco
Q Light Controller Plus version 4.13.0
Linux version 6.6.28+rpt-rpi-v8 (debian-kernel@lists.debian.org) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.6.28-1+rpt1 (2024-04-22)
Hi, what if you do it from a command line like this?
echo in > /sys/class/gpio/gpio18/direction
Do you get an error or does it work?
marcopiro
Thank you Massimo for your kind answer.
However I get:
bash: /sys/class/gpio/gpio18/direction: No such file or directory
No idea why!
However I must say: I'm not using your pre-built RPI image but I tried to install on my own. Same procedure done a year ago and it was working (I was on a previous Raspbian version).
I'll try to dig more.
Many thanks,
grazie :mrgreen:
Marco
