Hi, is there any way to add a small fade in and fade out to a flash button?
I want to be able to hit a keybinding that displays a scene for as long as i hold it.
Using flash function works but it seems to ignore any fades.
I need like 0.5 s fade because otherwise the flashes are way to heavy for the music genere.
Do i really have to make frame of type normal and add toggle button, meaning i would have to hit the button twice for a faded flash effect?
Cheers
Add fade to flash button
I have tried that, as well as using a speed dial. The flash button seems to ignore the setup fade of the function.
Unless with "scene" you mean something other than function.
I have attached a minimal example of my attempt.
- test.qxw
- (2.65 KiB) Downloaded 8 times
This statement is wrong ... flash is what it says and is intended to be: a flash button.
There are some workarounds on the forum. Search a little for them... it is even a hot topic...
- Real Name: Ken Coughlin
I don't typically use the Flash function. Similar to what ShagLight wrote, I create a scene which sets the fixture(s) in question to Brightness I want. I'll add that scene into a Chase, with 0 Fade-In, set the Hold to however long I want the fixture to stay on, then set the Fade-Out to a value that gives me the look I want.
- Real Name: David
You are right. For some reason I thought that worked like that. But after playing with it I found that for some reason, it will fade out but not fade in.
NO, I AM NOT THE SOUNDMAN!
