Smooth RGB Matrix
try to:
- make size bigger - bigger size - more steps - smoother color change; start with size of 20
- click on the clock button to set times - start with fade in hold 100 ms, fade in and fade out 0 ms
If that doesn't help, please tell us as much as possible:
- QLC+ version,
- operating system
- how do you output DMX
- what exact model are those lights
- attach your QXW file and any custom QXF here.
try to:
- QLC+ version,
- operating system
In the RGB Matrix editor (in the window on the right) on top you find an icon with a clock: if you click on that you can set the (fade in, fade out and) hold time of your RGB Matrix.
https://docs.qlcplus.org/v4/function-ma ... rix-editor
If you want to dynamically change the speed during your show, you could add a speed dial to your Virtual Console.
https://docs.qlcplus.org/v4/virtual-console/speed-dial
