missing VC Speed Dial: 2 proposals
giacomo
Good Sunday,
the Speed dial is a too important missing feature and for me it's drastically reducing the occasions to try v5,
in 2 weeks I'm doing some live performances and I'd have loved to use v5,
2 alternative proposals:
in VC it's already possible to open the function and change the timing
this is not a practical way to do it, so would it be possible to assign an external control to the time widget?
it should work without opening the time widget, only by selecting the function on the side list.
of course the external control should have a range of time like in v4, at least to control sec and ms together.
2nd and more advanced alternative: what about a speed dial that controls the functions inside a frame?
it would speedup the process and allow the insertion of functions on the fly, there could be a rule that a function is controlled only if not already running when inserted.
any other suggestions are welcome.
please the Speed widget soon ;)
