I have installed 4.13 on Linux and Windows.
I wrote an Application that uses the web api. That worked before 4.13 but now, Qlc crashes on Windows and Linux. On Windows with no messages, on Linux it says only segmentation fault.
Any suggestions?
[Edit] It seems this happens, when Qlc+ is started without loaded the project file.
Holger
Segmentation Fault on Linux and Windows by accessing the WebAPI
There's been a bunch of changes to the Web API which I sponsored including new widgets.
Do you use any of these widgets?
Guys, there are no new web API for the widgets that's been added.
The only thing that needs to be documented is the asynchronous message to indicate Function status change. Will do it ASAP
If a new API is added, it will be written in the changelog.
