frames multipages insides into other frame
i have a big problem: in VD exist a frame with 5 pages, and inside page 4 theres a frame with 3 frames; when start operation mode, always page 2 its selected; and if select page 5 the second frame select page 3 (not page 1). why?
... when start operation mode, always page 2 its selected....
The explanation could be that page 2 was active when you saved your workspace.
Just skip to the page you want QLC to start with (probably page 1) and then save your workspace.
The explanation could be that you use External Controls "Previous Page" and "Next Page" to skip the pages of your Multi Page Frame and that you used the same values in both your Multi Page Frames.and if select page 5 the second frame select page 3 (not page 1)
That's what i can come up with, based on the information you provided.
If this does not solve your problem, please post your workfile.
