While exploring what scripts can do, I realized when they are done running they turn off everything that they turned on. That's great, but what if I want it to run "forever" until I turn a Script function off? The "wait" popup doesn't have an "infinite hold" checkbox, which I assume means the syntax doesn't support an infinity option either.
Is there any reason not to add support for an infinite wait? I'd be willing to give it a go sometime if it makes sense to do. Obviously it would only make sense at the end of a script, since there's no mechanism I can see to tell it to move to the next step...
Infinite wait in Scripts?
The maximum value you can enter for the "wait" is 595 Hours (which is 24,79 days).
The shows i run last no longer than 2 - 3 hours, so to me there is no difference between 595 hours and infinite.
So keen for the javascript rewrite of scripts in V5. It's going to be awesome.
