Reproducible Crash changing time in a chaser
giacomo
Hi, linux Beta 3 and also tested with the last git v5 appimage:
1. open the file;
2. function manager, double click on the chaser;
3. add a new step (and if you like close the add tab);
4. double click on the fade-in or fade-out time and add or subtract a sec >> Crash
FXabsolute.qxw
(7.05 KiB) Downloaded 18 times
I've noticed it last week but I didn't have time to find it, my workaround for now it's to save and reload the show every time I change the chaser.
After a reload it's possible to change the time.
giacomo
Edit:
I've updated the title because it's happening always, even with a single dimmer and 2 scenes.
It's a common operation when programming a show, I've found that it happens only when adding a scene, not when removing one.
Xfade.qxw
(3.43 KiB) Downloaded 10 times
