Good morning
I would like to know how I can limit the movement of my moving heads so that they do not come back to me when I put them in a collection made from an efx in line or other.
I am attaching the working file if it can be useful to you.
THANKS
limit the movement of a moving head.
- Real Name: olivier
- test 4.qxw
- (34.65 KiB) Downloaded 8 times
hello
Sorry i have forget the fixtures.
thanks to help me and i sorry for my english i'm french
- BoomToneDJ-Maxi-test-60.qxf
- (4.61 KiB) Downloaded 10 times
I cannot believe that a manufacturer releases a fixture with the TEST in its name.
Had to change your fixture profile.
Your project file does not contain the right mode for the fixture.
I gave up... very inconsistent project.
You can limit the movements of the heads by using the channel modifiers or in EFX using the sliders limiting its movement.
In the on-line manual for the X-Y Pad, there is a paragraph about "Limiting the working Area" : https://docs.qlcplus.org/v4/virtual-con ... rking-area
You could also watch this tutorial: https://youtu.be/8-bgVX4uT2E
