During the week I've used v5 and I've noticed an inconsistency when adjusting the intensity (position seems more wrong but I couldn't test it) of multiple selection.
Here the starting point, selected 2 and 4 fixtures.
inconsistency of delta values
After adjusting the intensity widget another time, I cannot reach the full value anymore .
You add a dmx value of 50 > the result it's not good > you subtract the same dmx value and you're back to the original state (of course when you don't exceed the limits)
A good week.
I don't know if there is a math behind it or it's a bug, I believe that the operations should be linear for easiness.You add a dmx value of 50 > the result it's not good > you subtract the same dmx value and you're back to the original state (of course when you don't exceed the limits)
A good week.
