Button not released with loopback @00
giacomo
trying the loopback I've found a bug in the button response:
it doesn't release when the loopback goes to 00, I've found that it goes off when the loopback is 01 or higher.
File attached for test with explanations in it.
The weird behavior is that if you keep playing the first chaser, the button is released the 2nd time that the loopback goes to 255.
There is also a knob controlled by the loopback and it behaves correctly, the bug seems only related to the button.
v5 beta 3 / Gnome
00.qxw
(6.92 KiB) Downloaded 9 times
MichelSliepenbeek
Real Name: Michel Sliepenbeek
It might be the same issue as: viewtopic.php?t=16270
