Autoscroll in Function Manager, please.
giacomo
it seems necessary to have auto scroll in Function Manager, or anyway a solution:
when organizing functions into folders it's likely to happen that these folders are out of the view, so how to move the functions there?
Tonight I faced a situation where I couldn't do it, even by using a mouse with a scroll wheel.
The folder "led" went up to the beginning of the list, while the led scenes where down, I've tried to select a scene and scroll up to reach the folder but every time the selection was lost in favor of a random different scene under the mouse.
If possible autoscroll would be nice in 2d View and Universe View too.
eg. when you move a fixture to an high address number the autoscroll would let you reach the desired position, or when the 2D View is zoomed and you do a rubber band selection, the autoscroll would let you extend the selection.
giacomo
As alternative, a folder could behave like a chaser: a double click opens a window where we can add/remove functions, change the order or duplicate them.
Thanks.
