'Acts on' fixture definition editor
Can the Fixture definition editor be changed so that there is some notice that the 'Acts On' setting is only used in specific cases and has to be set to '-' as a default?
While debugging another user's project today, I had 4 custom fixtdefs to be altered... because of the used 'acts on' selected setting...
MichelSliepenbeek
Real Name: Michel Sliepenbeek
The most common mistake/misunderstanding is to make a channel "act on itself".
If you don't provide the possibility to select that channel in the pop up screen of the Fixture Definition Editor, it would already make a difference.
