BoomToneDJ Maxi Spot 60
Fixture :
Manual :
Enjoy
- Real Name: Cédric Monféfoul
Need HELP with this one :
Channel 4 is controlling Colors but, in QLC+.. if you want to assign Channel Group to 1 colors.. it can't ! because if i move the "Color Channel Group" This affects the intensity of the light, which is not managed by the Spot on this channel.
You are posting in the wrong place - this is the fixture definition channel...
Look at your last picture ... You did select the intensity channel.
If the slider is in playback mode, it will influence the intensity of your fixture.
Sorry, it's complicated to explain, English is not my native language.
But I Slider "White" in the 1st image is supposed to control all the whites intensity of each device.
Except that: on the Maxi Spot 60, if I move the "white" slider it does not affect the intensity of the color... unlike other devices.
On the Maxi Spot 60, the color wheel shown in image 2 controls the colors... but not their intensity!
I hope I can make myself understood
There were still a few errors in the definition. Gobo pictures are still missing.
Fixed and added, thanks
