5beta3: GUI Language back to system language?
Dado
Real Name: Corrado
Hi team,
The QLC+5 beta3 GUI is starting in Italian , that's the Windows language.
I change it to use English but if I close it and reopen I found again the Italian language.
Did I miss anything or is it an issue?
Selected language is not saved anywhere yet.
Like QLC+ 4 though, you can start v5 with a specific language with a command line option.
Dado
Real Name: Corrado
ok thanks, it was just to point it out in case it needed fixing
I tested it with command line options and it works fine, thanks
