I've been trying to add a new custom fixture to qlc+ (fixture definitions and qxf files attached) I've a custom fixture before and was successful (file named uking-par works great as expected). However, I'm having a really hard time with the seemingly more simpler fixture which I named "Dan". The actual name of the fixture on the box says "XKL-A4". Btw Im using USB to wireless DMX device called an ENTTEC open dmx usb on one universe.
The XKL-A4 works great with the IR remote, good by using a manual dmx control, and good by the buttons on the back of the fixture. But as soon as I try QLC+ it gets weird. I'm using 72 channels with my other fixtures so I'm attempting to the A4s on channels 73 or 74 and up. Set up this way (and yes with the channel set on the fixture as such) it does absolutely nothing at all. If I add it to channel 1 and adjust channel 1 in the simple desk I do get the color red unxepectedly as according to the instructions (also attached) this should be a "total dimming" channel.
I'm also a little confused about one part of the channel definition functions for d001 and C001 where it says d001 "address code value (channel 7, it is used in prefessional stage lighting). If I try to set either d001 or C001 to anything they both mimic each other. EI if I set d001 to 7 as the instructions suggest and then set C001 to a channel... lets say channel 73. d001 changes to 73. Also, just through troubleshooting purposes I have tried to change the DMX Connector type to all options available and that doest seem to affect anything either... allthough Im not sure its supposed to or if thats just a discriptive item?
Any advice here anyone on getting these PARS working?
Custom fixture definition
I made some changes to your fixture definition:
- changed type to color changer (this only affects the icon that will be used in the fixture editor).
- added dimensions (this only affects the size the fixture will get in the fixture monitor).
- changed the "acts on" s. (if you had used the Fixture validator https://www.qlcplus.org/fixture_validator.php it would have told you )
- removed the Head (you only need this if your fixture has more than one head).
I don't think your Fixture Definition is causing your problems, but "just to be sure".
First thing to find out is whether your manual matches with your Fixture.
I suggest to set the fixture to D001. Add the attached Fixture Definition to your user library, open a new workspace and only add this fixture at DMX address 001.
Now use the simple desk and check if the channels act like described in the manual. So set the Master (channel 1) to 255 and now channel 2 should control Red, channel 3 should control Green and so on.
If the manual is not correct, change your Fixture Definition according to your findings.
I think the manual is showing some poor translation issues. My immediate guess is that the dXXX channels are the 7-channel mode as listed in the manual and the cXXX channels are a simple 3-channel mode (though since it's an RGBW fixture, I have no good guess what three channels that would be - maybe just RGB and ignore the white).
- Real Name: Philip Snyder
I'm an experienced DMX lighting guy... over 15 years I've done this. Bought American DJ Par 64s when I started at $200 each. So when I saw these I was excited because they're so inexpensive and claim to have the features I cared about (DMX mostly). Bought 6 of them. Here's my experience, and how to get what you want out of them!
They are NOT an easy to install and use light. For starters, when working with DMX it is important to understand how MOST DMX fixtures work. If you have a fixture that implements 10 channels of control and you address it to be DMX Address 5, then it occupies DMX channels 5 through 14. These LED pars claim to implement 7 channels (9 if you read the box).
The BIGGEST problem with these LED pars is that the DMX implementation is DONE WRONG and there is NO WAY to do a firmware update. Sounds like trash, right? Well... not exactly. We CAN work around the manufacturer failures! I used EMU (enttec lighting control software) to figure out what the f is going on. Here's the skinny:
When you address these lights, leave 16 channels per light fixture even though only 7 are defined (mistake #1). And when you set the DMX address on the back of the light, you need to realize they messed up here again (mistake #2). Addresses of 2 or 3 or 4 etc have to be multiplied by 16 and that number should be used as the starting address in your controlling software / hardware. So.... I have 6 of them. I placed them at 1, 17, 33, 49, 65 and 81. The 8th - 16th channel on each par does nothing as far as I can tell. This is completely backwards. I should be setting the lights DMX address to their starting address, NOT the number in the series of lights. SMH.
You COULD slap another fixture in at channel 8 - 16 with each led par block to recover your lost DMX address space. I dont have anything with 9 or less channels for this current setup so I'm just out of luck. Feel free to ask for some advice / assistance.
What a complete PITA. I'm just glad I was able to figure them out at all. I've attached my fixture definition for EMU and wish you luck bringing it into QLC+ (I did not have any luck, possibly because the USB dongle needs specific instantiation that the EMU software does but QLC+ does not)
- LED Par XKL-A4.femu.zip
- (738 Bytes) Downloaded 3 times
Welcome to the forum.dezinerdj wrote: ↑Tue May 14, 2024 10:41 am I'm an experienced DMX lighting guy... over 15 years I've done this. Bought American DJ Par 64s when I started at $200 each. So when I saw these I was excited because they're so inexpensive and claim to have the features I cared about (DMX mostly). Bought 6 of them. Here's my experience, and how to get what you want out of them!
Ow, boy—who has to be fired from the tech department? Insert dummy channels inside your fixture definition to fill the needed gap. Except for a small fixture doing strange things with its fine pan and tilt channels (firmware only looks at 7b values so 125, 126, 127, 0, 1), I never got such a struggle to deal with...
