Korg nanoKONTROL2 button LEDs
KrisKelvin
Real Name: 12312312
I use both Korg nanoKONTROL2 and Novation LaunchPadMini in the QLC+ 4.12 program under win10,
each device in its own universe.
a fixture file is installed for LaunchPadMini and through it I control the LEDs under the buttons on this device
how to control the button LEDs on nanoKONTROL2?
edogawa
Real Name: Edgar Aichinger
By adding Feedback to the universe the nanoKontrol2 is connected to? This used to work for me just fine...
KrisKelvin
Real Name: 12312312
edogawa wrote: Sun Feb 18, 2024 11:35 am By adding Feedback to the universe the nanoKontrol2 is connected to? This used to work for me just fine...
feedback installed, (photo)
With this option, pressing the button lights up the LED with this button.
but I want to randomly control all the LEDs individually, regardless of the button state
So are you asking for the nanoKONTOL2 to be used as a led-panel? Then you would need midi to be sent out as an output...
KrisKelvin
Real Name: 12312312
GGGss wrote: Mon Feb 19, 2024 9:52 am So are you asking for the nanoKONTOL2 to be used as a led-panel? Then you would need midi to be sent out as an output...
Thank you !!!! everything worked as I wanted!
here is the fixture file, maybe someone will find it useful
Korg-NanoKontrol2.qxf
(8.15 KiB) Downloaded 10 times
