Fixture monitor showing wrong fixture
ConnyGoat
Real Name: Conny J
Hi there!
I have some colorpalette from chauvet and they have 8 zones, 4x2.
In the fixture monitor its only showing 6 zones 3x2.
But if i try the qlc 5 beta, its showing it correctly.
like this:
Is there anything i can do in the qlc 4 to show them as they should? its hard to imagine the patterns with out the last 2 lines, or actually, when the 4th zone instead of up is in the bottom row.
Thanks to everyone!
janosvitok
Real Name: Jano Svitok
The problem is in dimensions:
- close QLC+
- open C:\QLC+\Fixtures\Chauvet\Chauvet-COLORpalette.qxf, go to line 208 and edit it so that it says: <Dimensions Weight="2.8" Width="428" Height="248" Depth="178"/>
- start QLC+ again
If it doesn't help, make the width a bit larger so 4 heads do fit (or make height smaller so the heads are smaller).
The head dimensions are not fixed, QLC+ tries to fit head to given dimensions, without knowing actual layout.
Depending on fixture dimensions, 8 heads may come out as
00000000
or
0000
0000
or even
000
000
00
ConnyGoat
Real Name: Conny J
That was the thing! Thank you janosvitok, now i understood how to edit those files :D
