Hi everyone,
I have an issue when using a "chaser within a chaser" with 2x moving heads I have.
I've created a chaser that moves 2x moving heads ("Left-center" and "Right-Center") in a loop.
The chaser tells the moving heads to go from point A to point B slowly, and go back to point A quickly, and repeat.
The chaser "by itself" works well, and you can see the "pan" values changing as desired in the "fixture monitor".
The chaser has 2x scenes in it, and the only difference between the scenes is some tilt/panning.
The problem is where I put the chaser ("Pre-show-MH-incoming") into my main chaser ("WIE-Lights"). As you can see in the video, when I put the "Pre-show" chaser inside the "WIE-Lights", the chaser (Pre-show) doesn't "fade in/out", but just "jumps" between the points A and B.
https://www.youtube.com/watch?v=TNj3Ztp9nfg
I'm attaching the template.
I'm using QLC+ 4.12.7 on Windows 10.
Did I miss something?
Thank you so much!!
Sophia
Chaser within a chaser - moving head doesn't fade
- Real Name: Sophia
- 2-15-2024.qxw
- (423.6 KiB) Downloaded 14 times
To be able to debug your project, I would need the custom fixture definitions.
If a chaser has a sub chaser as step, timing should be set in the subchaser and the hold duration set in the parent chaser.All electric machines work on smoke... when the smoke escapes... they don't work anymore
- Real Name: Sophia
I'm attaching all the custom fixtures to the post.
Regardless, it seems like adding the "fade in/hold" timing to the external chaser ("WIE-Lights") doesn't allow the inner chaser to run in loop.
In other words, the inner chaser bounce between two scenes endlessly.
When I put a timer in the external chaser for the inner chaser (Pre-show-MH-incoming), the "Pre-show-MH-incoming" runs only once (instead of running again and again).
Any suggestions?
Thank you so much!
Sophia
Any suggestions?
Thank you so much!
Sophia
- Chauvet-Freedom-Stick.qxf
- (20.13 KiB) Downloaded 9 times
- American-DJ-WiFly-BAR-QA5-my.qxf
- (8.63 KiB) Downloaded 9 times
- American-DJ-WiFly-Bar-QA5-forum.qxf
- (13.99 KiB) Downloaded 8 times
- Real Name: Sophia
More fixture definition
- Chauvet-Intimidator-SPOT-XYZ-my-v2.qxf
- (8.04 KiB) Downloaded 8 times
- Chauvet-Intimidator-SPOT-XYZ-my.qxf
- (7.77 KiB) Downloaded 7 times
- Chauvet-Intimidator-Spot-Duo-155.qxf
- (24.01 KiB) Downloaded 8 times
- Real Name: Sophia
More fixture definitions
- Stage_Right-Wash-7x12W-RGBW-Zoom-Moving-Head.qxf
- (3.22 KiB) Downloaded 11 times
- House-lights-Dimmer-Pack.qxf
- (817 Bytes) Downloaded 7 times
- Elation-SIX-PAR-Z19-IP.qxf
- (8.41 KiB) Downloaded 6 times
- Real Name: Ken Coughlin
Looking at you WIE-Lights Chase, you have Pre-show-MH-incoming set to Fade In 0, Hold โ, Fade Out 0. This will cause your Left-Center-Moving-Head to jump from position 60 to 99 and back.
Changing your first step to have an 8s Fade In, will get you closer to how your Pre-show-MH-incoming Chase is set up. I don't know that you will get it to work exactly, since the outer Chase timing takes precedence over the inner Chase.
Did you change your Hold value to something other than Infinite?
