i tried some improvments to my project in qlc and after like 6 hours i run into weird behavior...
after some testing i noticed that
1st - strobo does not turn off when i swith it of with buttons (x and y keybind)
2nd - after i push play button - OPERATE MODE- All of my frames are disabled..
also i tried to keybind some buttons to ´´ (button on the left next to backspace) and then press it -> sometimes it turns of frames too.. realy weird...
visible on this video https://youtu.be/EjYQPVUApoM
lates qlc 4.12.7
Strobe value not reseting
- Real Name: Jakub Suk
- HANAČKA - PRODUKCE 2024 - upg.qxw
- (91.74 KiB) Downloaded 12 times
About your Strobe:
On the Fixtures Tab, if you select Channel Fade Configuration, you should notice that your Strobe Channels are set up as LTP.
If you change this to HTP your Fixtures will behave like you expect them to do.
An alternative would be to create a "Strobe Off" scene (set all Strobe Channels to Zero) and ensure it is active all the time (you could add it to your Start Up function) or put it in a Solo Frame together with your "Strobe On" scene.
Ofcourse, you could also use the RGB Matrix with pattern = Strobe.
