Is there a way to activate the internal pull up resistors for gpio on the raspberry (original image) version
if i check /sys/class/gpio/gpio17 the file active_low has 0 in it so the input should be up.....
gpio internal pull up
Did you define the direction of the GPIO port? in / out?
echo out > /sys/class/gpio/gpio18/direction
- Real Name: han sommen
thanks for your suggestion, it gives No such file or directory but on gpio17 there is nothing responced
in qlc i can configure pin 17 as input so i did that, for this time i placed 10k resistor as pull-up so my show is running. I made this show in a compiled version of qlc + wiring-pi but the startup time was too long and i decided to use the original image file (€15) and there is no access to gpio in terminal
Just keep in mind that QLC+ reacts on a rising edge signal on the GPIO. So you need 2 edges to switch from a zero to a one and back to zero. (Or you use a Schmidt trigger circuitry.)
