Definition needed for Chauvet Intimidator Spot Duo 155
Sophia1
Real Name: Sophia
Hi everyone,
I have the Chauvet Intimidator Spot Duo 155, but it seems that there's no definition for it in QLC :(
I did find the "Intimidator Spot Duo" (not the 155) in QLC.
I read the process of "editing a definition" but tbh it looks pretty intimidating to me :|
Would anyone be kind enough to help me add the Intimidator Spot Duo 155 to QLC? 😍
I'm attaching the "quick reference" for the 155.
Thank you so much!! ❤️
Sophia
There already is a slight variant of this fixture present: Chauvet-Intimidator-Spot-Duo.
With some love and tweaking, you can tweak the channels needed, based on this defintion.
Do not forget to change channels for both heads. (They are already defined).
ausmichael
Please see attached :)
I created this fixture profile based off the Intimidator Spot 155 (non-Duo)
Hopefully this will get you off the ground but I do encourage you to tinker with the software
The disadvantage of community software is we don't have every fixture profile
The positive is that with a bit of know-how, you can create any fixture profile with 30 minutes and a laptop
Chauvet-Intimidator-Spot-Duo-155.qxf
(24.01 KiB) Downloaded 13 times
Sophia1
Real Name: Sophia
ausmichael wrote: Wed Feb 14, 2024 8:53 am Please see attached :)
Thank you so much for all your work!! 😍
Sophia
Fixed a few errors and added to library, thanks
