Hi all,
I use QLC+ for theater shows, and I am very satisfied with it.
I suggest an improvement (or thank you for your help if this function already exists.):
In the virtual console, in a widget, an activated object (e.g. a sound) is surrounded by a green frame. When the sound is finished, is this possible to surround it with another color (example red) ? So we can see that it has already been used and we could see the progress of the objects used in the widget.
Hope I was clear !
Have a good week,
All my best from France.
Dominique
Status feedback from a button/widget.
If you use QLC as it was designed for, a Light controller (not a media player), all the buttons on your VC would turn red in a matter of time.
So for most of the QLC users this is not a good idea.
Why not use a Chaser with a Cue List to launch your Sounds from?
If in theater, the best workflow is working with master-chasers, sub-chasers and if needed, sub-sub-chasers.
In combination with collections (which can start different things at once - an often forgotten feature of QLC+) it is a very nice solution for plays. While rehearsing, you can very quickly swap to the chapter to be rehearsed.
