I use Novation LaunchPads and map the buttons to buttons in QLC which trigger different scenes. This has worked great but I recently purchased a new LaunchPad then realized the older one I had wasn't velocity sensitive and the new one is. The new one is much more senstive and sometimes as I am pressing one button my finger or palm lightly touches another button which then activates the wrong scene. Is there a way to setup QLC so that it filters out any midi note with a velocity under a certain value like 50? This would be nice so I don't end up accidentally triggering scenes by lighly touching buttons.
-Andrew V. Romero
Midi Velocity Filter
I don't think this will be possible because this will influence a lot of other midi devices also.
Can't you disable the velocity setting in your device?
