Hi guys,
I think I discovered a bug.
When I am loading attached workspace, open an arbitrary scene, select a fixture and then trying to open the color tool, no color tool appears.
Ubuntu seems to notice that a new window should be opened (another dot next to QLC+ icon), but it is not visible. QLC+ UI is locked, until I use right click on QLC icon on starter -> "Exit 2 Windows". Then, the invisible color tool window is gone and I can use the UI again.
Interestingly, everything works when using a blank new workspace.
Is there something wrong with this workspace file?
Logs do not seem to display anything related.
QLC+ 4.12.7
Tested on:
Ubuntu 22.04.3 LTS
Intel NUC PC
Intel(R) Pentium(R) Silver J5005 CPU @ 1.50GHz
Best regards,
Lukas
Color Tool not visible with special workspace file
- Real Name: Lukas
- 2024-01 Zeal 2024.qxw
- (20.74 KiB) Downloaded 42 times
We lack the fixture profile to do some tests, but I can already say that the color preview for a multi-headed fixture is troublesome.
I would say you had another display connected and the tool is displayed somewhere outside the main display.
If that's the case, you need to reset the QLC+ settings and the issue is not related to the workspace itself.
- Real Name: Lukas
Ah sorry, please find attached
This was not the case, only one display connected.mcallegari wrote: ↑Wed Feb 07, 2024 9:56 am I would say you had another display connected and the tool is displayed somewhere outside the main display.
But anyways, how can one reset the QLC+ settings?
- Futurelight-Stage-Pixel-Bar-10.qxf
- (16.91 KiB) Downloaded 38 times
Settings are basically here (platform-dependent)
https://docs.qlcplus.org/v4/advanced/parameters-tuning
- Real Name: Lukas
Okay, but this is global for all workspaces, correct? Because when creating a new workspace everything works fine, even with the fixture in question.mcallegari wrote: ↑Wed Feb 07, 2024 11:15 am Settings are basically here (platform-dependent)
Quickly tested on Windows. Works for me with your workspace. Color tool is displayed in the center of the screen.
I think there is something we're missing here but couldn't understand what exactly.
- Real Name: Lukas
I quickly tested on Windows as well, there it works for me too...mcallegari wrote: ↑Wed Feb 07, 2024 4:48 pm Quickly tested on Windows. Works for me with your workspace. Color tool is displayed in the center of the screen.
It feels like this is more a Qt-relatet thingy. Is there any chance to get more debug output? Tried with console option -d 0/3 but only very few lines there.
- sbenejam
On Ubuntu 22.04, KDE Plasma (x11) and QLC+ 4.12.8-GIT It works as expected.
Here's Linux too.
No idea what's going on in your Ubuntu. Perhaps look at Qt settings in your
$HOME/.local/share/
- Real Name: Lukas
Okay this is really strange. I did a lot of fiddling the xml code to find out that actually the SpeedDial widget in VC is causing the trouble.
If I delete it in the _broken file, everything is back to normal.
If I create a SpeedDial widget in the _works file, everything still works until I re-open the file, then it is broken as well.
I have attached a picture of how the "stuck" Color Tool window looks like on my ubuntu.
In addition, a screenshot of how the color tool looks on my side when opened normally (this is different from your screenshot so just wanted to point this out).
- 2024-01 Zeal 2024_works.qxw
- (19.21 KiB) Downloaded 26 times
- 2024-01 Zeal 2024_broken.qxw
- (19.69 KiB) Downloaded 20 times
Do you have a GitHub account?
Can you please try the latest build from GitHub Actions?
That looks like a Qt issue/incompatibility
- Real Name: Lukas
Just realised that this version produces some UI Glitches as shown in attached screenshots, so I guess it won't be released too soon...
- Bildschirmfoto vom 2024-02-19 03-39-12.png (9.11 KiB) Viewed 774 times
