Color Tool not visible with special workspace file
Posted: Tue Feb 06, 2024 9:47 pm
by siegmund
Hi guys,
I think I discovered a bug.
When I am loading attached workspace, open an arbitrary scene, select a fixture and then trying to open the color tool, no color tool appears.
Ubuntu seems to notice that a new window should be opened (another dot next to QLC+ icon), but it is not visible. QLC+ UI is locked, until I use right click on QLC icon on starter -> "Exit 2 Windows". Then, the invisible color tool window is gone and I can use the UI again.
Interestingly, everything works when using a blank new workspace.
Is there something wrong with this workspace file?
Logs do not seem to display anything related.
QLC+ 4.12.7
Tested on:
Ubuntu 22.04.3 LTS
Intel NUC PC
Intel(R) Pentium(R) Silver J5005 CPU @ 1.50GHz
Best regards,
Lukas
Re: Color Tool not visible with special workspace file
Posted: Wed Feb 07, 2024 9:06 am
We lack the fixture profile to do some tests, but I can already say that the color preview for a multi-headed fixture is troublesome.
Posted: Wed Feb 07, 2024 9:56 am
I would say you had another display connected and the tool is displayed somewhere outside the main display.
If that's the case, you need to reset the QLC+ settings and the issue is not related to the workspace itself.
Posted: Wed Feb 07, 2024 11:11 am
by siegmund
GGGss wrote: ↑Wed Feb 07, 2024 9:06 am
Ah sorry, please find attached
mcallegari wrote: ↑Wed Feb 07, 2024 9:56 am
This was not the case, only one display connected.
But anyways, how can one reset the QLC+ settings?
Posted: Wed Feb 07, 2024 11:15 am
Posted: Wed Feb 07, 2024 11:18 am
by siegmund
Okay, but this is global for all workspaces, correct? Because when creating a new workspace everything works fine, even with the fixture in question.
Posted: Wed Feb 07, 2024 4:48 pm
Quickly tested on Windows. Works for me with your workspace. Color tool is displayed in the center of the screen.
I think there is something we're missing here but couldn't understand what exactly.
Posted: Wed Feb 07, 2024 5:13 pm
by siegmund
mcallegari wrote: ↑Wed Feb 07, 2024 4:48 pm
I quickly tested on Windows as well, there it works for me too...
It feels like this is more a Qt-relatet thingy. Is there any chance to get more debug output? Tried with console option -d 0/3 but only very few lines there.
Posted: Wed Feb 07, 2024 8:09 pm
by sbenejam
On Ubuntu 22.04, KDE Plasma (x11) and QLC+ 4.12.8-GIT It works as expected.
Posted: Wed Feb 07, 2024 10:48 pm
Here's Linux too.
No idea what's going on in your Ubuntu. Perhaps look at Qt settings in your
Posted: Fri Feb 16, 2024 9:45 am
by siegmund
Okay this is really strange. I did a lot of fiddling the xml code to find out that actually the SpeedDial widget in VC is causing the trouble.
If I delete it in the _broken file, everything is back to normal.
If I create a SpeedDial widget in the _works file, everything still works until I re-open the file, then it is broken as well.
I have attached a picture of how the "stuck" Color Tool window looks like on my ubuntu.
In addition, a screenshot of how the color tool looks on my side when opened normally (this is different from your screenshot so just wanted to point this out).
Posted: Fri Feb 16, 2024 10:03 am
by siegmund
Here the picture of how the stuck window looks
Posted: Fri Feb 16, 2024 1:38 pm
Do you have a GitHub account?
Can you please try the latest build from GitHub Actions?
That looks like a Qt issue/incompatibility
Posted: Mon Feb 19, 2024 1:42 am
by siegmund
Latest build from GitHub Actions works as expected. I see the same Color tool as visible for you.
Do you have any indication on when the next release is planned?
Posted: Mon Feb 19, 2024 2:40 am
by siegmund
Just realised that this version produces some UI Glitches as shown in attached screenshots, so I guess it won't be released too soon...
