Fun Generation LED Diamond Dome MK II 32
Cheng
Real Name: Christian
home: https://www.thomann.de/intl/fun_generat ... _mk_ii.htm
manual: https://www.thomann.de/intl/fun_generat ... _mk_ii.htm
I guess, this was a easy on. At channel 8 the manual tells:
0....5 Motor on, static position
6…127 Motor position
128…255 Motor speed
I called the channel motor and the Typ speed
as I am pretty new it would be a good thing, if an expert just checks if everything ist ok. Validation is fine.
chers
Cheng
Fun-Generation-LED-Diamond-Dome-MK-II.qxf
(2.3 KiB) Downloaded 26 times
Cheng
change
it has 6 x 1 Watt. so 600 Lumen should be maximum.
(2.3 KiB) Downloaded 25 times
