Hey Guys
I found a strange addressing problem on my QLC configuration.
Here is a simplified version with
- 1 Color Changer (channels 42-48)
- 1 moving head (channels 279-289)
What is happening:
- i start a simple scene with the color changer , without strob (channel #47=0)
- i start another scene in a XY PAD , with the moving head (including only 1 tilt channel , as i know it is the source of the problem)
=>Result : the strob channel ( #47) is modify to 1 on the color changer and it starts to blink
This is not happening outside the XY Pad , or when i set the moving head channel beginning at 300.
This is directly caused by channel #281 of the moving head (tilt), when it is used through the XY Pad.
My configuration file is in attachment ....you can test the virtual console
Thx
DMX addressing conflict?
- fixtures_Hong-Yi-HY-G60.qxf
- (5.42 KiB) Downloaded 24 times
- 12X10W-Chinois.qxf
- (1.27 KiB) Downloaded 22 times
- TEST.qxw
- (3.82 KiB) Downloaded 32 times
- sbenejam
Can you share your custom fixtures definitions?.
This is a bug - Presets used in the XY-pad do spit out strange values to fixtures not included inside the XY-pad.
Reproduce steps:
* go into produce mode
* open DMX monitor
* select 'new scene 2'
+ verify the outcome, pan and tilt channels are set.
* deselect 'new scene 2'
* select the 'new scene 2' as a preset in the XY pad.
!! now, you can detect that the blue channel of the 12x10 fixture gets a 1 and the chutter channel also gets a 1 as values.
* Selecting the reset all button to undo these false values.
Reproduce steps:
* open DMX monitor
- XY-pad_mal_behavior.qxw
- (4.79 KiB) Downloaded 21 times
- sbenejam
I've tried these steps and I can't reproduce this behavior. Tested in Ubuntu 22.04 with QLC+ 4.13.0-GIT.
