Hi everyone,
i was looking for some hacks and i see this image in the landing page.
from this layout, it seem you can execute a color (eg Red) for all of your groups, by selecting the red button in the first raw.
but how can you press a single key to activate all of the scenes below? or is it linked to another function? in that case if Led pars is already blue, it will result Magenta. What am I missing?
thanks
f
multiple scenes with a single button
If you have a closer look at the image you attached (which by the way, is the "web interface" look on this one: https://www.qlcplus.org/user/pages/01.h ... onsole.PNG), you will notice that the color buttons are in Solo Frames.in that case if Led pars is already blue, it will result Magenta. What am I missing?
If the Led Par was Blue because you pressed the Blue Button first and now you press the Red Button (in the same Frame), it will turn Red (because the Solo Frame will stop the Blue Scene).
You could read this: https://docs.qlcplus.org/v4/virtual-console/solo-frame
If the Led Par was Blue because of another Scene being active (not within the same Solo Frame) and now you press the Red button, it will result in Magenta (if your Led Par is set to HTP. If your Fixture is set up for LTP however, it will turn Red).
You could read this: https://docs.qlcplus.org/v4/fixture-man ... properties.
or watch this video: https://youtu.be/Jj9YsHNQIXo?feature=shared
As you are a member of this forum for only 1 day and this is your very first post, i assume you are not an experienced QLC user yet (apologies if i underestimate you with that ).
So i suggest you start with watching the following videos: https://youtube.com/playlist?list=PLHT- ... ure=shared
and maybe some of these: https://youtube.com/playlist?list=PL_kj ... ure=shared
After that you could have a look at https://www.qlcplus.org/forum/viewtopic.php?t=16900 to find a possible solution for your question: "how can you press a single key to activate all of the scenes below?"
