Linking a dimmer to audio trigger
Summerbreeze
I have Robe ColorMix 575 AT colorchangers. QLC+ allows you to make a scene from only one color (let's say green), but so that the dimmer is tied to the microphone?
I tied the dimmer to the slider, the slider to the audio trigger, but it only works correctly when I hold it down with the mouse and don't release it.
Am I doing something wrong in the settings or is this a glitch?
Video here: https://drive.google.com/file/d/1-atSwf ... sp=sharing
MichelSliepenbeek
Real Name: Michel Sliepenbeek
Just turn the "Monitor the selected channels and update the slider level" option off.
Summerbreeze
MichelSliepenbeek wrote: Thu Jan 11, 2024 8:27 pm Just turn the "Monitor the selected channels and update the slider level" option off.
It doesn't work :(
Video screenshot:
https://drive.google.com/file/d/1pfirDM ... share_link
MichelSliepenbeek
Have a look at your scene "Green (2 .........)".
I guess you not only set the color, but also set the level channel to full. That does override your "sound trigger".
