16b tilt/pan EFX
Posted: Wed Jan 10, 2024 4:25 pm
Thanks to Massimo, the 16b tilt/pan problem is almost aside.
Now a new problem has arisen: the EFX module is going bizarre.
Of course, it does: the updated QLC+ engine made a MaJoR upgrade, dealing with the lower 8-bits of the 16-bit signals.
What an achievement!! ... If you have fixtures capable of fine-tuning dim, pan, tilt, //// , you will be soooooo happy now!
The issue: EFX does not take into account the ?? values ??? MSB / LSB ??? I cannot debug this behavior...
Project attached: PTissueControl5
You need a fixture definition: attached also
And a video to show what's going wrong ... [edit: https://youtu.be/cJTJZNaEkYA ]
