Hello, I found a problem in QLC+
Hastenal
Real Name: Max Suvorov
When I went into the simple panel and clicked on the channel intensity icon, a window appeared. I can’t close it, the button doesn’t work and a white rectangle appears in the background. See the picture.
Hastenal
If you go to another panel and then go back, the problem is solved
Hi, I fixed this issue. Thanks for reporting
